I’m wanting to configure some midi out functionality for my controller, so that leds can be controlled based on various states in the app.
Is there any documentation detailing the schema or options available in the midi mapping file?
I found some old examples of midi mapping files that are in xml format, but on my version of djay pro (Windows 5.0.6405.0), the midimapping file looks like json. Which is the correct file format, or do both work?
