Midi mapping for djay PRO AI on the iPad
I’d like to do some Midi mapping on djay PRO AI per this discussion here which is closed >> MIDI *output* mapping djay pro 2 - controller LEDs
but I can’t find the .djayMidiMapping as described by @TheRumbler
Has anyone tried this in the iPad? Where is this file located?
@tfmeier in the Files App on iPad, go to the djay folder. All Midi mapping files are stored here.
The file should be on your iPad in the Djay folder as described. But normally you don’t need it to change the mapping. This is easier (and safer) to do directly from Djay Pro. Of course, you can also make changes directly in the configuration file itself with an editor, but then you should know what you’re doing, because you can also break a lot.
