MIDI mapping for library selection knob
I have been trying to get a generic rotary encoder to act like the library rotary encoder on a DJ controller. I have the rotary signal mapped to “Move Library Selection (Rotary)”, but am unclear what to map the encoder click to.
I want to be able to navigate in and out of folders and select playlists (as is the standard with most controllers). What should I map the click to? I have tried all of the options in the dropdown shown below, but none seem to work.
With my Midifighter Twister, i have it set to “Load track on Deck 1” (or 2, but you could choose “selected deck”), the target beeing “music library”.
This is what I use @shmimel. This allows you to switch between playlist and song scrolling.
This ended up working! I think I was gaslighting myself into remembering track selection differently hahaha
Ok I was looking for a resolution to this. If I am using the FLX10 I want a press on the rotary I use to browse the library to open a folder instead of switching the library table.
If I have a folder selected in the tree view, if there are folders or playlists inside it I would expect a press to open the folder, instead it switches table and lets me browse ALL the tracks inside the folder. This is not the expected behaviour!
