I have started on a midi mapping for Traktor S4 MK2.
Almost everything is done, but i cannot solve how to use the touch on the jog wheels. Does anybody know how to map Jog wheels properly?
Here is link to my mapping:
http://mrdeejay.se/djayPro/Traktor%20…
guisim
June 12, 2017, 7:59am
2
Hi Björn,
thank you for your effort and sharing your mapping.
Can you send us a screenshot of the advanced midi mapping settings of your jogwheels?
Thank you in advance.
Cheers,Lukas E.
Hi Björn,
thank you for your screenshots. The Scratch Mode button is mapped correctly, here is a mapping of the Scratch command you might want to try out:
Please tell us if the mapping is working.
Cheers,Lukas E.
Hi Björn,
Cheers,Lukas E.
Photo of jogwheel setup. NOT the setup in provided mapping file.
Photo on setup in the provided mapping file above:
Hi Lukas,
Sorry, that did not change much.
When i press Jog wheel (CC3) Nothing happens.
When i press Jog wheel AND rotating (CC3+CC2) only rotate (CC2) executes.
That is my biggest problem, if i do both press and turn only turn (CC2) executes.
You may delete this doublette ;D
Hi Guillaume.
I’ve seen your cool posts in the nearby.
Did you finally solved eache and every problem of the mapping with Traktor S4 MKII using the resource you’ve posted on github?
Best. Francesco
Hi Guilaume.
I have downloaded the mapping. - Quit Djay and open the file, it asks if I want to install. - I restart DJay and nothing happens.
I click on configure and nothings been inputted.
Any suggestions?
