Your question:
Does anybody know a way to midi map cueing headphones for decks 3 and 4 using a two channel controller? I have a RANE One but use the iPad to mix with 4 decks using the touchscreen capability. I need to be able to cue up on decks 3and 4. Any ideas? Maybe shift+headphone select
Hi @DJ_A_Diffrance, this should be pretty straight forward using the djay MIDI Learn tool.
- While in the MIDI Learn tool, simply press an available button on your controller that you want to MIDI map to Deck 3 headphone cue.
- Now set the Target to Mixer.
- Finally set the Action to Deck 3: Monitor Active.
- Then repeat this for Deck 4: Monitor Active.
For more info on MIDI mapping on iOS, please refer to the linked FAQ below:
Yoooooooo thanks sir!!! I guess I just have to decide which buttons to use lol.
You could try using Shift + Headphone Cue as a button for this action
You’re welcome @DJ_A_Diffrance
