MIDI Mapping Neural Mix Mute
Hello,
I’d like to know how I can map the Neural Mix Mute functions to the performance pads. It’s really tedious to have to click them with the mouse every time.
I prefer using Neural Mix Mute because it adds an echo effect and the stems don’t cut out abruptly. What is the name of this function in the MIDI mapping section so I can assign it to a pad?
Thank you.
Hi @Francisco_Concepcion, I’ve moved your comment to its own topic. The MIDI command you are looking for is called Neural Mix Mute. There are several options available depend on how many NM Parts you typically use. I personally use 4 Neural Mix Parts.
Work in windows?
Yeah, same MIDI commands on Windows @Francisco_Concepcion
thank you!
No problem, you’re welcome @Francisco_Concepcion
