When i midi map stems acapella to 1 button and instrumental to another. I want the button to turn off the other button when I press the opposite. Example, I’m using a Ddj 1000srt and have the parameter buttons set to enable and disable the acappella and instrumental. My issue is when I press the left button for acappella the light come on and it’s isolated. But if I then press the right button for instrumental, I want it to turn off the acappella automatically. Instead it turn both light on and disables stems. To turn offf the light I have to press one of the buttons to turn off the light and enabling the opposite.
I’m sorry if this sound confusing.
