I’m currently remap the buttons of the XP2, cause i don’t like, how Djay implemented it to this controller…
So I mapped the first 4 buttons to the 4-CH Neural “mute” buttons and the buttons 5-8 I mapped them to “exclusive only” that when I hit one button, the other 3 Stems will be muted.
But my problem is;
When hit the Button for “Acapella Solo exclusive”, the Instrus are muted in the music, but the color of the pads (Bass, Melody, Drums) are still lighted up. But the should not light up at this time, cause they are muted.
What can I do, that these STEM Buttons no longer light up when I hit the “acapella solo exclusive” pad?
Thanks a lot for your help!
Is the “MIDI Out” option enabled for these “Solo Exclusive” actions?
The only way I managed to reproduce this issue on my iPad with the Akai MidiMix controller was by turning off “MIDI Out”.
However, this does not necessarily mean there is no bug. It could still be something specific to the combination of macOS and XP2, or even related to a particular version of Djay and the specific firmware version installed on the XP2.
ok i found out the problem:
The problem was, that when I use at one mapping the 4CH Stems and for the other ones the 2CH mappings. So I dublicated the midi buttons and put 3 different controls on one pad. That everything is mapped to the 4CH. Now it lights on and off, how it should be.
Glad you were able to sort it out @djscode. Thanks for the follow up.
