Midi-mapping the length of beatjump
Hello! For beat jumps, midi-mapping options are currently:
  • skip duration + or -
  • skip ___ beats forward/backwards
I would love it if there were midi mapping options to set the length of the jumps to a specific amount. For example “set beat jump length to 16”, same for 32, 8, etc.
Thank you!
Thanks for the suggestion! I’ll share this with the devs for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature.
Can you please also explain in more detail why the existing MIDI commands don’t meet your needs?
  • Skip Duration + or -
  • Skip “X” beats Forward/Backwards
Thank you for the reply and consideration! The currently available commands are great and I am fine using them, I just think it would be also neat if there were more options. For me, I use the DDJ Rev-7, and I think it would be cool if the 4 shortcut pads above the wheel could be midi mapped to “set beat jump to 4 beats” “…8 beats” “…16 beats” “…32 beats”, and then I could see easily and quickly which one is currently selected on my board.
You’re welcome @djmikelujan. Thanks for the additional info and clarification of your specific use case. I’ll pass this onto the devs.
