MIDI OUT Sequencer Question
  1. I have no bug to report, just questions about the Midi out function. I’m aware of how to send midi in from extra controllers, but I haven’t yet tried using my controller to send midi thru to my sequencer to create a type of remix looper. I was wondering with something like AUM, or Audio MIDI setup, that would be possible to just route the incoming messages through a device computer or ios, and to a second sequencer that’s routed and mapped to Djay already
just a bit confused on midi out option in advanced configuration options
Hi @miles_holt, the MIDI Out function within the djay MIDI Learn tool is for LED control of your connected controller only. To send MIDI to other equipment you will need to use another app or piece of hardware.
Will buy a midi router. Thank you for clearing that up
You’re welcome @miles_holt
in order to transform ableton link to midi
you would require external application like midi link sync or link to midi
link to midi does ableton link to midi
midi link sync does both directions also does tap to link(i dont think this application is available on the istore anymore)
another external bpm app which might come in handy, although not the best for tight clock integration is a app named “Auto BPM” which will take a audio signal and analyse constantly and convert to a midi clock/tempo…
normally best if you have a solid rhythm section or drum section to sync off basically a “audio to midi clock” app, similar to ableton follow
Yeah. This isn’t what I mean. I have my clocking figured out. I mean note messages, from controller to my sequencer and back to my controller and thus djay with djay as the in between. I know it’s possible with my sequencer as the origin point, but never tried with the controller as the origin point
Hi again @miles_holt, I’ve merged your previous topic into this one as they are closely related.
