**YOUR QUESTION: Midi map glitch flx4
i did some remaping, and did something i should not.
now the music stops to play if i use neural mixing, and now there is a echo on any stem i remove.
i tried looking around for a reset of the midi, as i had of course, remade the original.
cuz this is driving me mad big time, as i would have thrown this into the mirror if i were 18, mad**
spending hours a day right now..
tnx! in ad wanz
happy on the new year crew and dejaiz on da interwabz <3
Hi @AndyBoPandy, you should be able to simply switch back to the FLX4 (built-in) MIDI mapping to use the original default mapping prior to your changes.
hello..
sorry for late reply-
i tried several times going back to the built in config and again tried remap the pads to stems.but they echo out if i turn them off.
and it still glitches and stops the music. ive recorded a video with my phone.
i have not reinstalled djay pro yet to se if it solvs it. but im gonna try that as well..
Hi again @AndyBoPandy, can you please upload your video here, plus screenshots of how you’ve MIDI mapped the STEMS? Makes sure the Advanced Control Configuration section is expanded in your MIDI mapping screenshots. Thanks!
on this edit 1. its shift + beatjump thats Neural STEMS
controlling active.
edit 3 its on the SAMPLE as on the video, but same thing happen on both.
sry for video. watched it now.shoulda coulda woulda recorded it lil better perhaps..
Hi @AndyBoPandy, thanks for the screenshots and video. Unfortunately, your video is pretty hard to follow. Can you please try using a screen recording on your Mac instead? Thanks!
@AndyBoPandy, first of all, please check if you have the Mute FX enabled. If so, please turn it OFF.
Now, instead of using the Neural Mix Active (4ch: …) MIDI commands for your 4 Pads, please map these to Neural Mix Solo (4ch: …) instead (see below):
