On djay for Mac, is there any way to set it so that if something is changed on software, midi controls do not effect it until it matches?
In other words, if I turn down volume on the mixer or speed on a turntable on screen (or via ‘sync’), can I make it so that my midi controller’s fader does not affect it until I move it to the same position as it shows on screen?
