MIDI What is the "selected" deck
In the MIDI settings you can map buttons to Actions on the “selected” deck? What is the currently selected deck?
  • Is it the deck that has CUE active?
  • Is it the deck where the crossfader currenlty is at? (to the left or right) If YES: Is cross fader assignemnt taken into account?
As far as my testing goes, none of the above seem to be true. For us it seems that the assigned deck on iOS is always Deck 1???
Ok i can partiall answer this: There are midi actions under General → Turntable selection to select a deck. Still would be cool to automatically assign the selected deck depending on the position of the cross-fader.
Hi Doogie,
It seems you mostly answered your own question. Do you need any more information?
Hi Dan!
Yes, it would be cool to automatically assign the selected deck depending on the position of the cross-fader. Is that possible?
