Minimum requirements for tablet
Hi!
To use Djay Pro for Android, what are the minimum requirements it must have to function correctly? RAM memory, processor …
Thank you!
Hi @Edu_Mico_Reyes,
Thank you for getting in touch and welcome to the community.
We are working on a new Android version and would be happy if you can check it out, the minimum requirements are Android 8.1 https://play.google.com/apps/testing/com.algoriddim.djay_free
