Missing BPM when doing a search
  • Device model ipad pro 11
  • Version of operating system 18.3.11
  • Version of djay 5.2.9
  • Hardware/controllers used just on ipad
: all my tracks have been analysed, but some tracks do not show the BPM and therefore go to the bottom of the list when doing them in order of BPM.
The system knows the bpm because when you load the track, it shows the bpm, but it does not show anything when searching.
I have only seen this with ITunes files and 1 local file (which is an acapella so maybe a false flag )
I have lots of tracks like this.
Hi @David_Bielby, sorry to hear you’re experiencing this issue. Can you please try re-analyzing these songs using the following method?
  1. Select the Check Mark at the top right of the playlist in the library view.
  2. Check off the songs with missing BPMs by selecting the Circles to the left of each song.
  3. Open the drop down menu at the top left of the playlist
  4. Select Analyze Songs.
That has worked. I had about 250/9000 that did not have a bpm.
Now they all have a bpm. Thank you
Excellent! You’re welcome @David_Bielby. Happy to help!
