Missing crossfader
Hello,
I’m using DJPro v5.4 on Windows 11 and have two questions:
  1. How do I enable and view the crossfader between decks?
  2. Can I hide the FX panels to the left and right of the jog wheels while maintaining my current view?
Hi @DJRolo, welcome to the Community!
  1. Crossfader: what DJ controller are you using? It appears you have an External Mixer Mode device. In which case, the Crossfader is hidden automatically as it’s being controlled by your hardware and not within the software
  2. FX Panels: you can remove the FX and Hot Cue section to the right of the jog wheel by deselecting them in the top menu bar
