I’m missing master tempo in the android version of djay. Wher can I find the botton to activate that?
(In the iOS version there is an small music note (key lock) icon which I can click therefore).
Thanks for any help in advance.
Hi Ueli,
What exactly do you mean by “Master Tempo”?
Only the BPM of the loaded tracks are displayed (at the right upper corner)…
I think he meant mixing with tempo, 'cause android version only mix with pitch.
