Mix Now Button Midi Mapping
  • Device model (e.g. 2020 iPad Air 4th Gen): Lenovo Thinkpad
  • Version of operating system (e.g. macOS 14.4.1): W11
  • Version of djay (e.g. 5.1.2): newest
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Numark Mixtrack Platinum
    • Hardware firmware version (e.g. 1.0.1): newest
YOUR QUESTION:
  1. Is there a way to map the “Mix Now” button as a MIDI button? I couldn’t find it in the MIDI mapping settings. I use it a lot because I want to be able to decide when to fade out without having to set it in advance. Right now, I just press the key on my laptop, but I’d like to assign it to my controller.
Hi @steffen.krummen2, welcome to the Community!
You’re right that there’s no action called “Mix Now” in the MIDI mapping list. You can get close, though, by mapping a spare button to one of the crossfader transition actions:
  1. In your Mixtrack Platinum’s mapping, press the button you want to use.
  2. Set the Target to Mixer.
  3. Set the Action to Transition to Inactive Deck. If you’d rather have one button per direction, use Transition to Left and Transition to Right instead.
I hope that helps!
