Hi everyone, trying to map the loop encoder on my mixars Quattro but anything I do makes the loop continue to half of or double depending on the direction I twist the encoder. Has anyone any help in mapping the encoder to work correctly? Other than that I have the mixer working wonderfully with it!
What do you actually want the encoder to do, if not halve or double?
I want to turn it and have it go up in increments of half or double depending on what way I turn it. It does do it but it won’t stop and carries on to the end of each side for ev 1/8 or 32
Hi @Dennis_Collins, can you please provide a screen shot of your MIDI settings for the Loop Encoder with the Advanced Control Configuration section expanded? Thanks.
I sold it and bought a reloop elite!
