Except if you have ever taken a music theory class then you’d know that’s not how keys are used ((MIK). It’s like a DJ using the phrase “32 Beat intro”. They sound like an idiot because in music theory there’s no such animal. Music is composed in measures not “beats”. Musical phrases are in 8 measure sequences so referring to an 8 measure music phrase as “32 Beat intro” is like me trying to describe those things you kick below the frame of your car. You know? Those circular things the car rides on? They rotate in a circle? “You mean a tire?”
I’ve made my point. Describing a tire as a “round circular thing that rotated and you kick” is what I hear when a DJ says “32 Beat intro”. You mean 8 measures?
By the way that “8 measures” is part of the music writing notation process as well
A verse is considered Theme A. A chorus is Theme B the second verse is then considered Theme A variation 1 and the chorus? You guessed it: Theme B variation 1. Then there’s Theme C which in pop music is sometimes referred to as “middle 8” which then resolves itself back to Theme B variation 2 and end of song.
This is actually the formula not only for all song writing but dates back to Bach, Beethoven, Mozart, all the way up to modern composers.
As owner of Razormaid I took pride in making sure our subscribers were the most well informed DJ’s out there hammering correct terminology and usage into them since day one and have been doing so the past 30 years. As a Conducting Major and minor in Music Theory I felt communication key to our members and I didn’t want them sounding illiterate The more they new about how things should be done correctly the more they could appreciate HOW we did things correctly.
This followed through to the artists as well. With over 3,000 artists in our roster we were never turned down when requesting to work on the tracks from the artists because they quickly learned we would adhere to strict music theory process - including correctly identifying the key of there song.
Theoretically there’s only seven positions when computing keys. The optimum being 4th’s and 5th’s. 3rds and 6th’s are less desirable but doable leaving 2nds and 7th’s more challenging but the reward is the greatest. Unfortunately these last two can only be used when moving up in key not down. In other wards Ab>Bb. Or E>Gb, etc. (whole tone). Once you understand basic Nico theory you just swap out the letter name
7. B. G
6. A. F
5. G. E
4. F. D
3. E. C.
2. D. B
- C. A
Depending on the letter (key) you start with determine the key correction I listed the C octave and A octave in the example but you can see there’s only 7 positions. At Razormaid! we only use flats not sharps to limit confuse so if every letter is two half steps you’d have Ab, Bb, etc
My point being… when you buy a pitch pipe it only lists the 12 keys available in an octave, not some bizarre “system” trying to reinvent the wheel (MIK). There’s 12 notes in a octave on piano keyboard so there’s 12 pitches on a pitch pipe. Done. Unless you’re one of those people still try’ing to come up with a name for those circular things that are round and rotate under your car? (Hint: they’re called tires)
