Can you make a Spotify playlist and insert tracks you’ve got on your computer into the Spotify playlist?
Hi Peter Simon Christensen,
I moved this to the Idea section so people can give there Likes.
In the meantime you can try to workaround your problem by using the History section, playlists stored in the History can include both Spotify and local stored tracks.
Thank you for your feedback,
cheers.
I’d second this idea. Would be useful but on my Beatpad 2 it’s as easy as a press of a button to switch between Spotify and user playlists.
