Hi
I think a real improvement to facilitate mixing in Key would be for any tracks that match the key of the currently playing song to automatically be highlighted as opposed to using the filters as this can be time consuming. Similar to Rekordbox which highlights all the songs that match the currently playing songs key.
This way the option is still there to mix with songs that aren’t in Key as they don’t disappear, which is what happens currently when you use the filter option in djay. It also means that when you change song you don’t have to change the filter settings, which is currently what you have to do if the song is not the exact same key but simply a compatible key. For example, I have a filter which I use for songs in G major, which includes any songs in G, C or D. If I move to a song in D I need to change filter to songs in D, A or G. The Rekordbox method is much simpler to use.
