- Device model - iPad Pro 6th gen:
- Version of operating system *(ios 16.6:
- Version of djay 5.3.2
- Hardware/controllers used Reloop Mixon 4:
Hi everyone, I’ve recently bought a usb-c to vga to link my iPad Pro to my Mixon 4. I am having issues with the pre cue as I am not hearing any music through my headphones, only sound from the track that is playing through the speakers of the cue vol is turned up. Has anyone experienced this, I have tried all sorts & I can’t get it to work. Can anyone help?
Hi @Nick_Walters, welcome to the Community!
- Does your USB-C adapter also have pass through power? Please share specifics and pictures of this adapter.
- If the adapter has power input, are you connecting your original iPad charger and cable to the adapter? If so, is your iPad charging normally?
- Is your Mixon 4 connected to power with the supplied adapter?
- Are you using the latest firmware from Reloop?
- Are you using the built-in MIDI mapping or a custom edit?
- Please share screenshots of your djay Settings>Audio Devices and Settings>MIDI Devices
Please also check the position of the Cue/Mix knob and ensure that the Cue button is enabled.
Think I have sorted it, found this setting at the bottom of sound.
Excellent! Glad you sorted it out @Nick_Walters
