When in playing a track on either deck while it’s playing I cannot rotate the song back
But when it’s paused I can rotate back or forward
Have you checked in which mode you are in? Please use Shift + Slip to activate the Vinyl mode of the Mixon 4. Is this helping?
A year later it’s still does not work
I been using my 201& iPad instead of the 2020 iPad Pro
What really sucks is that my 2018 is getting slow and apple won’t replace the battery
Hey @Juan_Perez,
Could you please check/answer to the following things:
I hope we can fix this soon.
Cheers,G
The only work around somewhat but I loose the ability to pitch bend is to change the midi setting to scratch none touch I have the latest software and firmware and latest app
Everything works flawlessly on the 2018 but the 2020 is literally nit being used for DJing like I want it to.
I have
2 iPad Pro 12.9 2018
2 iPad Pro 12.9 2020
Mixtour paid it forward once I got the buddy
Buddy works perfect with 2020 iPad Pro 12.9
Mixon 4 issues with 2020 perfect with 2018
The only controller I’m having issues with is the Mixon 4
I am 100% committed to using iPad for DJing been on it at all my events since 2013 concerts with 1000s of people or small private events with a couple 100 I love the feel of DJing with a touch screen and a controller Djay software is the best!
