Mixon 4 with djay 5.2
Does mixon 4 works well with djay 5.2 ? (its cheap…)
I particularly want to use the equaliser knobs (high mid low) in Neural mix mode. Does it works?
Any limitation on Mixon 4 in djay 5.2?
I saw there’s a mapping of Mixon 4 for traktor 2 on the website. will it work for traktor 3?
I m thinking of going from traktor to djay and testing with my controller S2MK3. Nice but 2 channel and missing cues color pad.
Thanks.
Hi @PatriceCros, yes, the Reloop Mixon 4 is fully supported for djay 5.2 on Windows and macOS. You can also toggle between regular EQs and Neural Mix EQs.
