I just receive my Mixon 4.
The mapping with Iphone and Ipad is directly applicable. But I need to manually configure the controller with djay pro on my mac. Is it normal?
Thank you in advance,
They told me it will get nativ support in the next update.
They said soon! i guess in one or two weeks. This is a real guess.
yes as DJ Ivan said the update is coming soon
Sorry that we can not give out a particular date.
Cheers,Lukas E.
the Mixon 4 is now officially supported by djay Pro for the Mac.
To be able to use the Mixon 4 please update your software to version 1.4.1.
All the best,
cheers.
Thanks for your answer.
Do we have a date for the next update?
