Mixon 8 Crossfader keeps getting set to Dipped on relaunch
I’m running DJay Pro 5.6.6 on a 10th Gen iPad 64 along with a Reloop Mixon 8 Pro
  1. The crossfader gets automatically set to Dipped
  2. I change the crossfader to ‘Default’ in Settings > Sound
  3. Once DJay is restarted, crossfader is set to Dipped again
This behavior does not occur when I connect my Pioneer DJ DDJ-FLX4.
Hi @CHVCK_LEONE, welcome to the Community! What is the Crossfader Curve dial on the from of the Mixon 8 Pro set to? It’s on the front, left side of the unit.
Thanks, that did the trick! The CF curve was all the way counter clockwise. I turned clockwise it to just past 12 o’clock and it’s now staying at Default when restarting DJay.
You’re welcome @CHVCK_LEONE. Glad to hear that solved your issue. Thanks for the follow up!
