When adding in delay/echo FX on a specific channel then cutting the entire channel I was able to allow the delay/echo FX to fade out on the mixon 4. This doesn’t appear to do the same on the Mixon 8. Is this possible? Is there a setting that may need changing?
Thanks again for coming in CLUTCH Slak!
No problem! You’re welcome.
