MIXON 8 PRO Master Volume Issues
Can I ask why you would want master volume at 100%?
Well it’s not that I would want to do that….just putting my unit through testing to make sure it isn’t faulty since so many units seem to be…
When you say ā€œgetting clippingā€ how are you determining this?
Are you hearing distortion, or are you just assuming it’s ā€œclippingā€ because of what the meters are doing?
More testing - gain at 11 o clock. Auto gain on.
There is no sound between 0 and the first dot. If master volume is any louder than 3 or 4 o clock there is audible distortion and clipping.
I am also seeing the lights on each channel turn red indicating clipping.
This sounds like it could be a hardware issue. Have you contacted Reloop Support?
No I have not, the point of this post was the determine if there is a hardware issue. I can still return the unit and try a new one.
Have other users had similar issues?
You are the first user that I’m aware of on this forum to report this issue, however there have been other issues related to this hardware.
I’ve not heard of this particular issue. Some users have reported hardware issues inc myself.
