Mixtour Pro: 4 Deck Toolkit — Custom MIDI Map — Uploadable
SDDE + SDVS + SDCR | 4 Deck Workflow MIDI Mapping
As requested, I’ve put together a single Mixtour Pro MIDI mapping combining three workflow modifications I’ve been developing for 4-deck use in djay Pro.
The aim is simple: more direct physical control, fewer button presses, less screen interaction, and a more intuitive 4 deck workflow — while retaining the compact simplicity of the Mixtour Pro.
SDDE — Simple Direct Deck Engagement
Provides direct physical volume control of all four decks without layer switching.
  • Decks 1 & 2 retain their normal volume faders.
  • The two GAIN knobs are repurposed as direct volume controls for Decks 3 & 4.
  • This means all four deck volumes are immediately accessible at the same time.
Trade-off: Physical gain control from those two knobs is sacrificed in exchange for direct, simultaneous volume control of all four decks.
SDVS — Simple Direct View Switching
Provides immediate access to the two views I actually use:
  • SHIFT + Left FX Select → 2-Deck Pro view
  • SHIFT + Right FX Select → 4-Deck Pro view
Instead of cycling through layouts, one press takes you directly to the required view.
Trade-off: Effectively none in my configuration, as these shifted controls were previously vacant.
SDCR — Simple Direct Cue Recall
Uses SHIFT + Right Neural Mix to recall the prepared Start Cue state, allowing the decks to be quickly returned to their predetermined starting positions and paused.
This is particularly useful when setting up, rehearsing and repeating multi-deck sequences without manually resetting each deck every time.
Trade-off: The shifted Neural Mix control is repurposed for the recall function instead of its previous mapped behaviour.
Three small changes — one integrated workflow
Rather than sharing three separate MIDI modifications and asking people to recreate them individually, I’ve combined SDDE + SDVS + SDCR into one complete Mixtour Pro mapping.
The intention isn’t to add complexity or reinvent the Mixtour Pro. It’s to make better use of the physical controls already there and reduce some of the little workflow interruptions that become noticeable when operating four decks.
I’m sharing the configuration for other Mixtour Pro users to try in real-world use. I’d particularly appreciate feedback on workflow, usability, the trade-offs, and whether these changes genuinely make 4 deck operation more intuitive.
Mapping file
Small dose of irony here: I built this around the portability of the Mixtour Pro + iPad setup… and I’ve managed to travel without the Mixtour Pro. :grinning_face_with_smiling_eyes:
I’m away from home for the next two days, so I can’t export the mapping file until I’m back and can reconnect the controller.
I’ll add the downloadable configuration to this post as soon as I do.
Rick Vincent
Thanks for sharing @RickVincent. Looking forward to reviewing your mapping when you upload it.
Uploading: MIXTOUR_PRO_4DeckToolKit_v1.0.djayMidiMapping…
This is very nice. I did add similar functionality by sacrificing some shift-CUE pads, because I’m mostly in hot QUE mode, but going to try this mapping and use the pads for more creation related changes.
Another change I did is that for deck 1 and 2 I enabled ‘pick-up’ for smooth mixing, but due to my specific use of 3 and 4, I did disable that again so that upon loading of the track you can set EQ etc. with less margin of error.
Thanks and Kudo’s.
Reloop MIXTOUR PRO Edit.djayMidiMapping (278.2 KB)
Thanks will get a blast on this over the weekend
