Can I midi map the fx wet dry knob ? I want to Shift and move knob to control loop length
Hi @Nubium, SHIFT + the FX Wet/Dry knob on the Mixtour Pro does not send a separate MIDI command so this cannot be mapped to Loop Length.
The existing MIDI mapping can control Loop Length for each deck by pressing:
