I just received my new Mixtour Pro, which is advertized as Android compatible via Djay but I have several problems with it. I tried three different systems but they all have different failure modes:
with a Samsung S24 Ultra:
a) Audio works via Bluetooth, but pre-cue does not work (cannot even select channel)
b) if I remove BT and connect via RCA connector, pre-cue works but the music is played at 4 times the speed and cannot be slowed down. -
with a Samsung Tab7+:
a) Audio works via Bluetooth, but pre-cue does not work (volume for pre-cue moves but no sound)
b) if I remove BT and connect via RCA connector, no sound at all -
with an iPhone14:
Audio works ok, pre-cue works, but the phone does not charge (65W charger connected, the Android devices charge)
Is there a way to get the Android devices to work? They are my main devices.
Many thanks
