Device model: iPhone 12 Pro
Version of operating system: iOS 18.3.2
Version of djay: 5.3.1
Hardware/controllers used: Reloop Mixtour Pro
I have disabled Reset Neureal Mix Control in the Djay Pro 5.3 settings. I turn the knobs on the Mixtour Pro controller and visually see the sound wave changing, but if I go to the Neureal Mix section, the bars don’t change.
When I load a new track, I have Neureal Mix at 100%, even though I have the knob on the Mixtour Pro controller at 0%. In Djay Pro program slider position is also at 100%.
It’s confusing and there are always errors in the mix because I expect that there is no sound, but there is, although the knobs on the controller are turned to 0%.
I can visually see that the sound wave is visible, although I have the Reset Neureal Mix Control option disabled.
I’ve noticed that if I don’t use the Mixtour Pro controller, I only change the values in the Djay Pro - Neureal Mix app, everything works as I expect. When loading the next track, Neureal Mix stays at 0% as it was before.
I guess I need to wait for a new firmware for Mixtour Pro for this option to work properly.
It is very strange to see this on a controller that is specially designed for Djay Pro.
Please discuss this with Reloop and Algoriddim engineers. Perhaps there will be some solution to this problem?
Thanks.
