Hi, I recently bought the Mixtrack Quad, and would love to use it with djay on my ipad, however it is not currently supported.
Are there any plans to add this to the compatible controllers?
I wouldn’t expect all four decks to work, but just using the main two decks would be enough.
Hi Brian,
I’ll change your question into a feature request (= idea).
Thanks man, would be great to see
I would really like mixtrack quad to be supported on iPad Pro, please please please. It’s a really portable setup. Best regards Fredrick
