Mono output
I’d like to output in mono, but I can’t find an option to do that. I often dj on shitty speaker set ups (ftr, dj for social dance, mainly in dance studios and venues I can’t mess with) and I occasionally start playing a song only to have, say, the vocals totally absent. Currently using djay 4.0.2
I’m sorry, it is not possible to switch the Main Output to Mono within djay 4. However, you can get yourself an adapter with a Mono Output you can connect to your Mac.
Can this be done on DJay Pro for Windows 10?
I wanted to add this resource for anyone else who lands on this page like I did looking for a solution. If you’re on MacOS, you can sum your output to mono via an Accessibility setting.
http://www.macinstruct.com/node/431
