I love mute fx with echo, and the ability to choose the beat length, but I would also love more options besides echo. Specifically reverb and brake. And maybe the option to midi map the switching to those. Thanks team ![]()
Thanks for the suggestion @djmikelujan. I’ll share this with the devs for consideration.
- Please also consider sharing a short video or screenshots to help clarify your suggestion
YOUR SUGGESTION: Add more stem mute fx options other than just echo out.
- I like using echo out for when I mute vocals, but when I mute drums or instruments, I’d like to have the vinyl brakes effect. Serato and RB already have these options. PLEASE ADD THEM with the ability to assign it to just drums or instruments and vocals can stay as echo out. As of now. choosing echo out applies it to all 3 stem options.
Hi @AnthonyTon, I’ve merged your new suggestion with this existing one. Thanks for the additional input. Please vote above.
Totally agree, the Serato software when you kill the stems using the pad has like a sharp vinyl break effect which actually sounds really cool, no good to me as I’m 100% Djay Pro but if we could have more options on these NM stems it would definitely be a cool feature
Cheers
Cuzer
Thanks for the additional feedback @Cuzer
