It would be amazing if we had the ability to download our own scratch samples or even if you provided more scratch tools than just the 1 Qbert Scratch tool that is available now.
It would also be great if this function could be a midi map so we could switch this on off the selected channel.
Or even better if there was a way to keep whatever track you had playing on the channel and still switch into or switch on and off the scratch tools.
Thanks in advance.
