Mouse wheel sensitivity settings
I remember the last version came with a feature to where you could adjust something on a deck without clicking the mouse, and just roll the wheel. one slight roll would move something up or down, with this new version the mouse wheel function is unusable! iv searched everywhere in settings and watch youtube tutorial, and nothing about that is mentioned! If you know anything about this, please let me know.
Hi @John_Anthony_Webster, welcome to the Community! There are no mouse wheel adjustments specifically inside of djay. You will need to adjust this in your Windows system settings.
  • Press Win + I to open Settings.
  • Navigate to Bluetooth & devices, then click Mouse.
  • Under the Scrolling section you’ll find:
  • A dropdown labeled “Roll the mouse wheel to scroll”, where you can choose between:
    • Multiple lines at a time
    • One screen at a time
  • If you choose Multiple lines, use the “Lines to scroll at a time” slider to adjust how many lines are scrolled per wheel notch (commonly adjustable from 1 to 100, default is often around 3)
I hope that helps!
