Move EQ dropdown label above the EQs
YOUR SUGGESTION:
I strongly dislike the way this EQ menu dropdown is located. That should imply the knob below is it EQ, not the 3 on the side. there’s no mention of the single knob actually being gain. Am I being picky? yes. Also - that should just make sense.
Thanks for the suggestion @thedrummingdj. I with share this with our dev team for consideration. In the meantime, please use the blue Vote button so we can gauge user demand for this. Also, please note this is a dropdown menu to toggle between EQ, Neural Mix EQ and Neural Mix Crossfaders. Thanks!
sure! I know that - but I guess in a bit of a panic, I kept trying to change the EQ by moving the gain knob - becuase that knob is directly under the drop down that says EQ. or NM. just seems like poor UX placement. :slight_smile:
in any of the three options, that knob below it doesn’t change function. therefor, I think that dropdown is misplaced. that should be under or above what it actually changes.
Thanks for the additional feedback @thedrummingdj. I’ll let our team know.
