I’ve followed the directions but can’t make this work. I just want to move my playlists so they appear on the new machine. I have the “backup” folder on the desktop but even when I copy and past over the one that’s there the playlists don’t show up. What am I doing wrong?
So you are following the
https://help.algoriddim.com/hc/en-us/articles/360014912211 ?
Question: what playlist are you trying to move ?
Are you moving directories, which contains audio files and playlists?
Or are you trying to copy only the medialibrary?
- If you need to copy everything, I would copy the “Music” folder from old machine to new machine. And try to double/triple check that the folder structures are the same.
So if your mp3’s, playlists are on “Music”, you need to copy them to.
- Then I would try to copy the track analysis data
~/Library/Group Containers/VJXTL73S8G.com.algoriddim.userdata/Library/Application Support/Algoriddim/
What do you have in your “backup”?
So when you start up dj pro in a new machine, it will create empty file to this location:
That is the file what needs to be replaced with the same file from the old machine.
That file contains your media library.
Thank you. I solved my problem by transferring all files from the old
laptop to the new one. Like mirroring it.
