- Device model : MachBook Pro 13" 2017
- Version of operating system : 13.6.7
- Version of djay : 5.2
- Hardware/controllers used : Traktor Control S5
Summary of the issue:
Maybe I’m being stupid.
When I move the crossfader with the mouse, it behaves completely inverted.
With my controller, everything works without any problems.
I also noticed this in the last versions.
Have I changed a configuration?
Or is it really a bug?
I made a video of the behavior.
First I use the mouse and then the controller.
Thanks and regards Michael
Many thanks for the tip.
But this switch only affects the controller.
Unfortunately, it does not change the mouse movement.
Have you tried using the crossfader with the mouse?
Is it as it should be with you?
Regards Michael
Thanks for the details about your setup and the video @Qun. This is very helpful. I have forwarded this to the engineering team. I’ll report back here when I have news. Thanks!
Hi @MichaFalki, could you please check your Crossfader assignments in 4 deck mode (the “left” and “right” options)? Also, can you please try to capture a video in 4 Deck mode while moving the Crossfader with your mouse? Thanks!
Hello @Slak_Jaw ,
I did the update to 5.2.1 and then it worked. Without changing anything in the crossfader settings.
Anyway, it’s great that it works now.
Many thanks and best regards Michael
Excellent. Thanks for the follow up @MichaFalki. Glad to hear it’s working now.
