I’ve tried to load/play a number of MP3’s on my new install of DJay 2 on Android. Unfortunately the tracks won;t load.
Any advice?
Any advice?
Hi Colin Young,
could you contact us via support@algoriddim.com?
Please tell us which Android device you are using and it would be great if you could attach a track which is not working.
Thank you Colin we will get in touch via mail.
Hi
e-mail sent.
Hi
Thanks for the reply.
In case anyone has the same issue note from support:
Thank you very much for the information.
Please note that djay 2 for Android is not supported on devices with an Intel chipset.
We’re very sorry for the inconvenience.
