Is there any way to link multiple triggers/function together…
Ex: Say i want vinyl brake, and off stems for everything but vocals all done with 1 trigger whichever way, pads or button
Hi @Slim89, you can use the Duplicate function within the MIDI Learn tool to map multiple commands to the same control. On iOS press and slide left on the control to reveal the duplicate option.
I want to add the vinyl brake to neural mix while maintaining the vocals on whatever deck I’m using
You want the brake effect on the parts you’re turning off?
I can see an issue there. If you turn the parts off, there won’t be any audio to brake.
Hi @Slim89, probably the easiest way to do this is with the Manual FX and changing the assignment from Deck to Drums for the first FX Unit and to Harmonic for the second FX Unit (see below).
Yes exactly
I just want to brake everything except vocals
Hi @Slim89, if you combine both of my posts above, I believe you should be able to achieve the results you’re looking for.
EDIT: I mapped this to a performance pad on my Reloop Ready and it works as expected (see details below).
You can take this a step further and duplicate the same performance pad two more times and MIDI map these to:
This will make it so you don’t have to manually change these assignments from Deck to Drums and Harmonic within the FX Menu.
So the only things you need to manually set are the FX Selection (Vinyl Brake), FX Parameter (number of BEATS) and Wet/Dry (100%).
This work but doesn’t remove the bass but I just added another with mute neural mix bass…thanks for the help:muscle:t5:![]()
You’re welcome @Slim89
