Multiple machines settings reset to default overnight. Help needed.
Can I clarify…quoted from app store
Installation
Get this app while signed in to your Microsoft account and install on up to ten Windows 10 devices.
Does this mean I can install DJ pro on up to 10 machines. And use them simultaneously. Using different spotify premium logins??
Reason I ask is we are using on 2 different machines. And overnight 1 of the machines reset back to its default settings. Lost its Audio configs, turned on auto play on load, turned off load to load marker…Not a welcome sight at 5am. And this was it’s first day being used in anger on a new PC.
Second possibility.
We used to use DJ pro off and 1 mac 2 Ipads . And I cloud was syncing up cue points between studio’s. And worked fine for months.
So we installed I cloud for windows, this allowed us to select DJ pro 2 for I cloud syncing.
But is it rewriting settings as well. I suspect, and hope this is the answer because I have a mac and 2 Windows 10 machines syncing to this I cloud account. And it maybe confusing settings and resetting to default, put remembering cue points.
Can anyone help me with these 2 questions.
Hi Steve,
yes you can use djay Pro for Windows on all devices which are using the same Store ID.
Please note that syncing user data between Mac and Windows devices is not possible at the moment.
Where are these “Algoriddum employees” that are here to help.???
Still waiting for a reply
