Multiple MIDI Mapping Files Generated Each Time Pioneer DJM S11 is Connected/Disconnected
Device model: 2023 MacBook Pro M3 Max
Version of operating system: macOS 14.6.1 (Sonoma)
Version of djay: 5.1.2
Hardware/controllers used: Pioneer DJM S11
Summary of the issue:
Every time I newly connect my Pioneer DJM S11 while using my custom MIDI mapping, a new MIDI mapping file is automatically created. Over time, this leads to the accumulation of many unnecessary mapping files, which I have to delete manually. See screenshot:
How to reproduce the issue:
  1. Use a custom MIDI mapping in djay Pro with the Pioneer DJM S11.
  2. Connect and disconnect the DJM S11 from your MacBook Pro multiple times.
  3. Observe that each time, a new MIDI mapping file is generated.
Hi @trebbis,
Thanks for sharing this bug with us.
Our team is currently looking into this with the engineers for further investigation.
Looking forward to providing an update soon!
Okay thank you for the quick response. Looking forward for an update that fixes this.
Any update on this issue?
