music import of digital purchases from i tunes incomplete or not available
Summary of the issue:
How to reproduce the issue:
using
-Mac book pro mid 2015, 16 Gb
-macOS Monterey Vers. 12.7.6.
perviously it worked loading hundreds of songs from all playlists, since tow weeks import does not work at all. songs only appear in Apple Music streaming service , whereas the same songs purchased do not show in the local music folder :(((
Hi @sugarloo,
Sorry to see that you’re experiencing this library issue!
So that I can better assist you, could you please answer the following questions:
  1. What version of djay are you using?
  2. If you log out of Apple Music via djay for Mac, are you then able to see the tracks you purchased from the local library source?
  3. What made you need to re-import all these tracks again? Was there something wrong with your Mac or the djay app?
