Music Library Analysis
Upon loading my tracks, I just figured out something. The app can only analyse the beat, key and the waveform one by one, which in my opinion would be a hassle if one has hundreds of songs to analyse, like me.
Will there be a feature in the app whereby it can analyse all the tracks in the music library before the user can actually use the djay app? It would handy if there is.
Thanks for helping out Jerod!
Open your library like you are going to load a song, click on the songs list (so that way it analyzes all songs and not just a playlist or album, scroll to the top, hit the more button, then select analyze songs.
Thanks for the help, buddy! :slight_smile:
What if your on an ipad, there is no selection for analyze songs?
thanks
yatz
