Mute FX reverb out?
Is there an option to change Mute FX from echo out to reverb out? Sometimes I’d prefer a reverb cut vs echo tail out.
Your question:
Hi @megaman24, Mute FX can only use Echo Out. There is not option for Reverb Out.
Ok, thanks for the quick reply. Would be nice to have a reverb out option. Thanks so much for the quick updates too! You guys rock!
You’re welcome @megaman24
