Im getting to know more about the software but some things are not right in the app e.g mute until cue doesn’t show on screen if it is activated or not I hope this can be upgraded and the tempo soft takeover be an optional function thanks
Thanks for posting your question/feedback in our community!
Could you please explain in greater detail the issue you would like help with regarding djay? This’ll help our teams find our footing in understanding the explained problem.
Talk soon!
Thanks for your response the first thing is i think tempo soft takeover should be an optional function and the mute until cue doesnt show on the screen if turned on or off also instand doubles doesnt work well on some controllers like ddjsz srt1000 flx 10 the instant doubles need to be clicked multiple times bfr it reacts to the command
Thank you very much for the clarification.
I’ve passed this topic along to our engineering team for further review/consideration and will update this thread should new updates come in!
Have a nice day.
Would be looking forward for that thanks
