Hey Chris,
can you tell us which djay version you are using?
Hey Chris,
Hey ChrisM,
thank you for the follow up and I am glad that you managed to fix the issue.
Interesting, I forwarded this to our developers and we will investigate the issue, thank you for sharing.
Cheers,Lukas E.
I am using DJ Pro and connecting with the lightning cable. It recognizes that is connected because I can control the master volume and it plays. I did a total reset of my iPad last night and it did end up working! I see many have had this issue so it may be worthwhile to find the cause because resetting your iPad does give you other issues to deal with. Thanks for the response
